Error when using WinSCP to upload files: WinSCP.SessionRemoteException: Could not read status line:
Ganesh Mohite
HI Team,
We are getting below error when we connect with WinSCP.exe file
Error: Error when using WinSCP to upload files: WinSCP.SessionRemoteException: Could not read status line: An existing connection was forcibly closed by the remote host.
Please help me on the same
Description: please find error file
Re: Error when using WinSCP to upload files: WinSCP.SessionRemoteException: Could not read status line:
Can you transfer the files anyhow from the same machine? Using WinSCP GUI? using any other client? Post its log file too.
