Connect to S3 does not work. Connection failed in scripts
Hello
I am working on a automated script to connect to the S3 storage and put some files on that storage.
The GUI works fine but when i try to use a scripted version of this, it is not working.
I created a Batch file from the Generate session URL and use this for my script.
in the secret there is a
See the error below.
I hope somebody can help me out.
Version of WinSCP is 5.19.4 build 11829
Log attached.
I also used the PowerShell version but same issue
Log attached.
/, so the code changed that to %2F.
Log attached.
Log attached.
