Multiple Synch in 1 Instance
                Currently if we sync an folder on a remote server, the whole application is blocked.
If u want to sync 2 different folders to the same server or 1 folder to 2 servers simultaneously you have to open 2 WinSCP applications.
IMHO it would be a nice feature if we can start a sync and then open a new tab in the same application and sync there another folder instead of opening another instance of the program.
