Configure WinSCP for SFTP only, do not knock FTP port.
BryGuyT117
I see that WinSCP checks if FTP is available when SFTP fails. Can WinSCP be configured to never try FTP, do not look/check/try/knock, only use SFTP. If SFTP fails, game over. Do not try anything else for any reason.
Failed to connect to aaa.bbb.ccc.ddd: Network error: Connection timed out
Knocking FTP port.
FTP port opened, will suggest using FTP protocol.
Script: Network error: Connection to "example.com" timed out.
The server rejected SFTP connection, but it listens for FTP connections.
Did you want to use FTP protocol instead of SFTP? Prefer using encryption.
BryGuyT117
What I have checked thus far.
I have looked through WinSCP documentation, WinSCP forum, and web searches. I have been unable to find an answer to my inquiry. I will continue to research and will update this post if I find an answer before an answer is provided.
BryGuyT117
Thank you!
I appreciate your assistance with this, martin! Considering keywords on the linked page, I have no idea why my searches never brought this to light. Thank you for ending my headache.
