Script asks for password even though I do not have one configured
NewBieJeSuis
When I try to run the commands individually, no password is asked and I can easily connect to the server.
However, when I put all the commands in one .bat script it asks me for the password to enter the server even though I do not have one configured.
Do I need to have a password configured?
Re: Script asks for password even though I do not have one configured
Please post session logs from both scenarios.
