Copy files from many folders?
skyfay
Hey,
Sometimes I have a couple of folders and there are files in the folders.
Now I want to copy all the files from these folders to one place.
There is a search where I can e.g. search for *.txt files and then all of them are displayed in the folders.
But how can I then copy them all to one place?
It's annoying to open every folder and then move files around.
Thanks for the help
skyfay
Re: Copy files from many folders?
Thanks for the answer.
I don't want to download the files, but rather move them all to a specific folder on the host where I have connected ...
is that also possible?
No. But it's easy to build a script (or a WinSCP extension) to do that based on the results (copied to the clipboard using Copy Results).
skyfay
How exactly do I do that with the script?
Is it possible that this feature will come soon?
I currently always have to do this with SFTP via Windows. That's very annoying.
Just write a script in your favourite language that takes paths from the clipboard and processes them (e.g. with use of WinSCP .NET assembly).
Your request is rather unusual, so I do not think it will make it to core WinSCP.
How exactly are you doing this "with SFTP via Windows"?
