Error copying from Win10 drive to RPi/Volumio HDD
rhoneyman
Southfield, MI
Upgraded to latest version today. Tried to sync from my Win10 local to an HDD attached to my RPi running Volumio. I've attached a screenshot of the error as well as the session log. It seems that once the error message posts, the file transfer continues, I think on the file causing the error. Not sure. But the transfer rate is at a snail's pace.
Thanks in advance.
Re: Error copying from Win10 drive to RPi/Volumio HDD
What exactly is your question/problem? Are you asking why the transfer fails? Is it always the same file? "set times: Operation not permitted" happens, when scp tries to update the file timestamp and you are not an owner of the file.
