Connection Failed
Slanger
Connection Failed
I am not very knowledgeable with servers so I may just have a simple setting wrong here, but I have been using WinSCP for the past year a lot, and the program has been great – very easy to set up and use.
But in the past couple of weeks I am having a lot of trouble just signing into my FTP server, I keep getting
Connection Failed
Timeout detected. (control connection)
Connection failed.
on an endless loop.
I can sign into my server through the browser, but not WinSCP. Any advice is appreciated!
Re: Connection Failed
Are you able to login with any other client? Did you try contacting your server administrator/hosting provider?
Slanger
I haven't really had time to try out any others, this is the only one I have ever used. Which would you recommend trying? I desperately need something that works.
I spoke with the tech guy from the provider, they can't see anything on their end.
