Windows 11 Laptop / WinSCP
WB2HKK
Olb Bridge, NJ
I have a new 2022 Lenovo laptop with Windows 11 Home. WinSCP will NOT connect to my remote system running Linux. I just get a connection timeout. I CAN connect to the remote system with my Main PC on the same network. I am stumped. Turning off the firewall doesn't help. I also cannot ping the remote system from the laptop, but can from the main PC. Anyone else experience this? Looking for any suggestions.
Re: Windows 11 Laptop / WinSCP
Are the two machines connected to the same network?
If you cannot even ping the server, it does not seem to be a WinSCP issue.
Can you connect with any other client using the same protocol? Did you double check that you are trying to use the same protocol on the new machine as on the old one?
WB2HKK
BOTH are using the SFTP file protocol. Just tried again today after a Windows update. I CAN ping the remote IP (a Raspberry Pi running Linux), but WinSCP will still not connect, and neither will PuTTY. Not sure how to debug this. (Thanks for the reply!)
WB2HKK
Yes, both on same network. Took the laptop to a local Optimum hotspot, and got the same results, so the issue is with the laptop, not the network. Very puzzling!
Did you try to compare trace route? Also, unless you can connect with any other SSH/SFTP client, I do not think this is WinSCP issue. Consider asking it at Super User.
