Error code 2 on SCP file from local to remote computer
OokInTheComputer
South Africa
Good afternoon all
I have an issue with PowerShell and WinSCP.
Basically I have code which checks for replication on HyperV, then SCP the result to an SCP server.
So far the script works well, except when SCPing the file.
My code:
$transferResult =
$session.PutFiles("C:\Reports\*.htm", "/incoming/", $False, $transferOptions)
When the code is run, I get the following message :
Error: Exception calling "Check" with "0" argument(s): "Cannot create remote file '/incoming/FileName2022-01-12.htm'.
No such file or directory.
Error code: 2
Error message from server: No such file"
I have checked and verified that the SSH account do have write access to the specified account, and I have SCP'd successfully from another computer using Posh-SSH with the same account.
Thanking you for your assistance in this regard.
Re: Error code 2 on SCP file from local to remote computer
Is your account really chrooted? Shouldn't the path rather be like /home/user/incoming?
Can you upload the file using WinSCP GUI? If you can, have it generate a code template for you:
https://winscp.net/eng/docs/guide_automation#generating
If this does not help, post logs both from the GUI and the PowerShell.
See also Automate file transfers (or synchronization) to FTP server or SFTP server
