PowerShell – Automation – FileTransferProgress – Volume transferred
Claudio1983
Hi to all!
I need to expose the progress of file being transferred.
At the moment the script look like this:
function FileTransferProgress
    param($e)
    # New line for every new file
    if (($script:lastFileName -ne $Null) -and
        ($script:lastFileName -ne $e.FileName))
    { Write-Host }
    # Print transfer progress
    Write-Host ("`r{0} ({1:P0})" -f $e.FileName, $e.FileProgress)
    # Remember a name of the last file reported
    $script:lastFileName = $e.FileName
[...] #some stuff
$session.add_FileTransferProgress( { FileTransferProgress($_) } )
[...] #some stuff
This way, I get the percentage. What I need is the volume (if possible).
Thanks in advance for any help.
Full script attached if useful.
Have a nice day!
Claudio
Description: Full script
Re: PowerShell – Automation – FileTransferProgress – Volume transferred
WinSCP .NET assembly currently does not expose number of bytes transferred. But as you are uploading, you can query the size of the source file and estimate the bytes uploaded based on the FileProgress:
(Get-Item $e.FileName).Length * $e.FileProgress
