Network error: Software caused connection abort but only by UPLOAD via SFTP
Kyryl
Dear Martin,
After upgrade to version 5.19.5 I have a problem uploading files (download from the same server works fine).
WinSCP is scheduled (as scheduled tasks) to upload new files every 7 Min.
It works 10–20 times, but than there is a message in log
and each new start tries to upload the same file with the same error as result. After reboot the upload of the same file works again. I've seen this behavior for small csv files (1KB) but also for xls files (40–100KB).
What I have tried so far (found here in forum):
  • disable optimize connection buffer size
  • using additional PUT options -nopermissions -nopreservetime -resumesupport=off
but without success.
I'd very appreciate your help.
My log is attached.
Kind regards
Kyryl
  • WinSCP-Upload.20220202.txt (20.11 KB, Private file)
Re: Network error: Software caused connection abort but only by UPLOAD via SFTP
What version were you using before? Does it still work if you downgrade?
