BitLocker makes WinSCP always show Local Disk
Sopor
Sopor avatar
Sweden
When i put in my external drive that i use BitLocker on, the label will be "Local Disk" and when i have unlocked the drive it will change label to the correct one in the File Explorer.
The problem is that WinSCP will continue to show "Local Disk". I have tried to change drive and tried refreshing, but it won't change the name whatever i do. The only solution is to restart WinSCP.
In the attached picture you can see that there is a locked padlock as the drive is still locked. WinSCP will not update the drive list after the drive is unlocked.
Description: File Explorer
Description: Local Disk in WinSCP.
