Error: Received SSH2_MSG_CHANNEL_DATA for nonexistent channel 0
JimB
Guam
Trying to copy a 1.1TB file from local hard drive to VMware datastore and getting the error:
I copied the file from a VMware 5.5 datastore w/o incident but copying it back to VMware 7.0.2 ESXi generates the error every few seconds.
Any way to fix this? Using WinSCP v5.19.5
Re: Error: Received SSH2_MSG_CHANNEL_DATA for nonexistent channel 0
Please post session log file.
Can you upload the file using any other SFTP client? If you can, please post its verbose log file too.
JimB
I've tried a few other SFTP clients but the won't connect for some reason. I finally tried deleting the partial file transferred and started over from scratch yesterday. I came in this morning and about 160GB has copied over but WinSCP showed an out of memory error. I didn't save the log but will next time. Started it over again, had to delete the partial file.
JimB
Guam
Here is the message that appeared today:
(00407A58)
(00056FEE) ntdll.dll
(00CF32DB)
(00CF27E6)
That was in an error message that popped up: "Invalid Access to memory". I've attached the log from the session.
Description: transfer log
So what other client did you try? How did you configure it? What error did you get?
JimB
Guam
I tried bitkinex323, coreftplite64 and the solarwinds voyager software. None of them would even connect to the datastore, not sure why and I didn't spend much time on them.
What I have noticed is that it gets to 266GB then stops with a lost connection message. When I try and restart the download I get the 'Error: Received SSH2_MSG_CHANNEL_DATA for nonexistent channel 0' message. The file size is 1.1TB.
I was able to copy the file from ESX 5.5 datastore to a hard drive w/o any problems. But copying back to ESX 7.0 is giving me grief.
thank you...
Can you try some more mainstream client, like OpenSSH or FileZilla?
JimB
Guam
Hi Martin;
Ok, thanks I'll try after this weekend.
I had shutdown the server and copied the files from the ESX 5.5 datastore and was leaving the server down until I copied the files over and brought it up under ESX 7. Since I couldn't get the files copied and do this month's change on the relocated VM, I have to bring it back up under 5.5.
The server is a WSUS server and have a change scheduled for this weekend to install updates. By Monday I can shut it down and try copying it.
Loeke
I had the same problem today copying files from my Windows 10 PC to my Ubuntu server.
The cause appeared to be a full physical disc ....
Georgeis
I suffered the same issue by trying to run an Ubuntu VM, and finally when I copied to /VMFS/volumes/ on VMware ESXi datastore folder it allows to me to do it
me_2022
Not enough disk space
For me the problem solved by deleting some files from remote server, and freeing up enough disk space for the file + additional space
juanfernet007
Este problema ocurre porque el servidor tiene llena la partición donde desea adicionar el archivo.
Translation: This problem occurs because the server has full the partition where you want to add the file.
Graham Hardy
Classic error message
The error displayed means that you have insufficient space available on your file system or remote storage location.
Either increase the free space or perform house keeping so that you have enough space to accommodate the file copy.
roland
I got the same message when I transferred a large Zip Archive ~ 600MB. In my case, the message had nothing to do with free space. The target device still had enough free space to receive the same file 100 times. I continued the file transfer from the last position, but the file was corrupted afterwards. This issue is reproducible with version 6.3.4. I switched to Filezilla.
