Using $session.MoveFile
Mitakue
Paris
I need to write a PowerShell script to download some files of remote Unix server and after download I want to archive files in Archive folder.
The download works perfectly but the archive using $Session.MoveFile doesn't work.
This is my code:
$fileInfos = $session.EnumerateRemoteFiles($InputDir, $FilePattern, [WinSCP.EnumerationOptions]::MatchDirectories)
if ($fileInfos.Count -gt 0)
   foreach ($fileInfo in $fileInfos)
       Write-host("`r------ Action  --------------------`r")
       # Download files
       $transferResult = $session.GetFiles($fileInfo.FullName, "$OutputDir\", $False, $transferOptions)
       # Test file not Found
       if ($($transferResult.Transfers.count) -ne 0)
           #"[$todaylog] - [Action] $Action Transfer $filesCount files on $($transferResult.Transfers.count) : $($FileInfo.Name)" >> $LogFile
           Write-host("$todaylog Download $filesCount file(s) : $($FileInfo.Name)")
           $filesCount=$filesCount+1
           $file = $OutputDir+ "\" + $fileInfo.Name
           $separator = "."
           $parts = $fileInfo.Name.Split($separator)
           $file_basename = $parts[0]
           $file_extension = "." + $parts[1]
           #Destination de l'archive
           $DestinationFile = $ArchiveDir + "\" + $file_basename + "_" + $todayDate + $file_extension
           #Taille du Fichier
           $filesize=[math]::Round($($file.length / 1kb),2)
           #Comptage des lignes du fichier
           $lines = (get-content $file | measure-object -line).lines
           #$session.MoveFile($FilePattern, $DestinationFile)
           foreach ($transfer in $transferResult.Transfers)
               # Success or error?
               if ($transfer.Error -eq $Null)
                   Write-Host "    $InputDir/$fileInfo          "
                   Write-Host "Upload of $($transfer.FileName) succeeded, moving to backup"
                   # Upload succeeded, move source file to backup
                   $session.MoveFile(("$InputDir/$fileInfo", $ArchiveDir)).Check()
               else
                   Write-Host "Upload of $($transfer.FileName) failed: $($transfer.Error.Message)"
My SMA Opcon job is failed but I don't have any errors appears.
I have tried some syntax but I despair.
It's probably nothing at all but I can't find a solution.
Have you some idea?
Kind Regards,
Mitakue
Re: Using $session.MoveFile
Some hints:
  • Why "$InputDir/$fileInfo"? Use $transfer.FileName or $fileInfo.FullName
  • Use slash, not backslash, in $DestinationFile
What does it mean "is failed", when you "I don't have any errors"?
If you need further help, please attach a full session log file showing the problem (using the latest version of WinSCP).
