Download specific files by name
floody
Denmark
Hi all,
Currently I am using the following method to download multiple files based on file name e.g. report_*.xlsx.
Session.GetFiles
This works fine, but in some cases I would like specific which files to download e.g. Report_1.xlsx, Report_50.xlsx...
Is this possible using the above (or similar method) without going into a loop?
Cheers
floody
Denmark
Re: Download specific files by name
Thanks Martin,
The FileMask works perfectly.
I did try the loop but would have needed to handle the TransferResult differently.
Cheers
