Is there any way to hide the warning message?
Re: Is there any way to hide the warning message?
I assume the message says
The extension does not come from a trusted source. Are you sure you want to install it?
No, you cannot disable that warning. What's your use case? Who will be installing the extension?
marunowork
Thanks for the reply.
A few Japanese users, including myself.
