Session.GetFiles Method failed to copy in the local server
squayum
UK
I was trying to sync the local server with the remote server using WinSCP library in .NET C# environment (Assembly WinSCPnet, Version=1.5.3.8172, Culture=neutral, PublicKeyToken=2271ec4a3c56d0bf), using the method called GetFiles() in Session class.
But what happens GetFiles() method detects the modified files, but it does not transfer the file from the remote server to the local server. I don’t understand the reason. Has any of you experienced this problem, if so how you resolved this.
method below was used:
transferResult = s.GetFiles(ps.f_remote, ps.t_local, false, transferOptions);
Note transferResult.IsSuccess was set and transfer count was nonzero, but no file was copied in the local server. Do you have any idea why it fails to copy in the local server?
Reply with quote E-mail
Re: Session.GetFiles Method failed to copy in the local server
What do you mean by "method detects the modified files"? The Session.GetFiles does not do any "modified files" detection, at least not with the default settings.
Anyway, please attach a full session log file showing the problem (using the latest version of WinSCP).
squayum
UK
Martin,
Thanks for your reply. I modified some files in the remote server. Session.GetFiles() detects the changed files, but it did not sync/ or copy in the local server (on my local computer).
I did not understand the reason. I copied the log for you. The log shows it copied, but it did not copy to local server.
I also tried session.SynchronizeDirectories() method to synchronise my local server. Here the problem is setting time zone offset for day light saving. I can't see any option for setting this in the code. I set transfer options.FileMask = ">2022-04-04". This did not work either. Do you know the reason why it is not working?
