SFTP - Connecting with Zlib compression?
David Accola
What do I need to do to enable Zlib compression within WinSCP? I'd like to test whether the SFTP server I'm connecting to supports Zlib compression or not.
Full context:
When connecting to the SFTP server with a Java application, I'm getting the error
Caused by: com.jcraft.jsch.JSchException: Algorithm negotiation fail
When connecting with WinSCP I'm not able to reproduce the error. I'd like to investigate whether the difference is the compression algorithm the clients are using.
