Generate URL session - Use only Shell: default
I would like generate multiple URL to connect to whole servers list.
I saved a session that's working in WinSCP (5.19.6), then I did a right click to generate URL session. But when I use the URL, shell command is not execute.
In my session list, I select
URL looks like:
I enabled session log file in WinSCP and I see "Shell: default"!
I don't know how to find a solution.
Thanks for your help.
sudo su -
in shell options.
URL looks like:
winscp-scp://myuser; x-publickeyfile=C%3A%255CUsers%255Canuser%255C.ssh%255Cid_rsa.ppk; x-shell=sudo%2520su%2520-@ip-adress/
