z/OS PDS members without ISPF statistics are not listed
Consider a z/OS PDS named
Using the FTP transfer protocol,
WinSCP version: 5.19.6
First WinSCP version with problem: 5.18.beta
Last WinSCP version without problem: 5.17.10
WinSCP Version 5.19.6 (Build 12002 2022-02-22) (OS 10.0.19044 - Windows 10 Enterprise)
WinSCP Version 5.18 beta (Build 10932) (OS 10.0.19044 - Windows 10 Enterprise)
WinSCP Version 5.17.10 (Build 11087) (OS 10.0.19044 - Windows 10 Enterprise)
'CIETPFM.FTPLIB'
containing three members FILE1
, FILE2
and FILE3
VIEW CIETPFM.FTPLIB Row 0000001 of 0000003 Command ===> Scroll ===> PAGE Name Prompt Size Created Changed ID _________ FILE1 1 2022/05/03 2022/05/03 14:22:13 CIETPFM _________ FILE2 _________ FILE3 1 2022/05/03 2022/05/03 14:22:18 CIETPFM **End**
FILE2
is not listed by the ls
command:
winscp> ls D--------- 0 0 .. ---------- 0 1 May 3 14:22 FILE1 ---------- 0 1 May 3 14:22 FILE3 winscp>
> 2022-05-03 17:10:09.916 Script: ls . 2022-05-03 17:10:09.916 Retrieving directory listing... > 2022-05-03 17:10:09.916 TYPE A < 2022-05-03 17:10:09.920 200 Representation type is Ascii NonPrint > 2022-05-03 17:10:09.920 PASV < 2022-05-03 17:10:09.927 227 Entering Passive Mode (*,*,*,*,15,200) > 2022-05-03 17:10:09.927 LIST . 2022-05-03 17:10:09.927 Connecting to *.*.*.*:4040 ... < 2022-05-03 17:10:09.945 125 List started OK . 2022-05-03 17:10:09.951 Using TLSv1.3, cipher TLSv1.3: TLS_AES_256_GCM_SHA384, 2048 bit RSA, TLS_AES_256_GCM_SHA384 TLSv1.3 Kx=any Au=any Enc=AESGCM(256) Mac=AEAD . 2022-05-03 17:10:09.951 TLS connection established . 2022-05-03 17:10:09.954 Session ID reused . 2022-05-03 17:10:09.954 Cannot parse line: . 2022-05-03 17:10:09.954 Name VV.MM Created Changed Size Init Mod Id . 2022-05-03 17:10:09.954 FILE1 01.00 2022/05/03 2022/05/03 14:22 1 1 0 CIETPFM . 2022-05-03 17:10:09.954 Cannot parse line: . 2022-05-03 17:10:09.954 FILE2 . 2022-05-03 17:10:09.954 FILE3 01.00 2022/05/03 2022/05/03 14:22 1 1 0 CIETPFM . 2022-05-03 17:10:09.954 Data connection closed < 2022-05-03 17:10:09.960 250 List completed successfully. . 2022-05-03 17:10:09.960 Directory listing successful . 2022-05-03 17:10:09.960 ..;D;0;1899-12-30T01:00:00.000Z;0;"" [0];"" [0];---------;0 . 2022-05-03 17:10:09.960 FILE1;-;1;2022-05-03T12:22:00.000Z;1;"" [0];"" [0];---------;0 . 2022-05-03 17:10:09.960 FILE3;-;1;2022-05-03T12:22:00.000Z;1;"" [0];"" [0];---------;0 < 2022-05-03 17:10:09.960 Script: D--------- 0 0 .. < 2022-05-03 17:10:09.960 Script: ---------- 0 1 May 3 14:22 FILE1 < 2022-05-03 17:10:09.960 Script: ---------- 0 1 May 3 14:22 FILE3
> 2022-05-03 17:06:38.224 Script: ls . 2022-05-03 17:06:38.225 Retrieving directory listing... > 2022-05-03 17:06:38.225 TYPE A < 2022-05-03 17:06:38.229 200 Representation type is Ascii NonPrint > 2022-05-03 17:06:38.229 PASV < 2022-05-03 17:06:38.233 227 Entering Passive Mode (*,*,*,*,15,194) > 2022-05-03 17:06:38.233 LIST . 2022-05-03 17:06:38.233 Connecting to *.*.*.*:4034 ... < 2022-05-03 17:06:38.254 125 List started OK . 2022-05-03 17:06:38.255 Using TLSv1.3, cipher TLSv1.3: TLS_AES_256_GCM_SHA384, 2048 bit RSA, TLS_AES_256_GCM_SHA384 TLSv1.3 Kx=any Au=any Enc=AESGCM(256) Mac=AEAD . 2022-05-03 17:06:38.255 TLS connection established . 2022-05-03 17:06:38.258 Session ID reused . 2022-05-03 17:06:38.258 Data connection closed . 2022-05-03 17:06:38.258 Name VV.MM Created Changed Size Init Mod Id . 2022-05-03 17:06:38.258 FILE1 01.00 2022/05/03 2022/05/03 14:22 1 1 0 CIETPFM . 2022-05-03 17:06:38.258 FILE2 . 2022-05-03 17:06:38.258 FILE3 01.00 2022/05/03 2022/05/03 14:22 1 1 0 CIETPFM < 2022-05-03 17:06:38.261 250 List completed successfully. . 2022-05-03 17:06:38.261 Directory listing successful . 2022-05-03 17:06:38.261 ..;D;0;1899-12-30T01:00:00.000Z;0;"" [0];"" [0];---------;0 . 2022-05-03 17:06:38.261 FILE1;-;1;2022-05-03T12:22:00.000Z;1;"" [0];"" [0];---------;0 . 2022-05-03 17:06:38.261 FILE3;-;1;2022-05-03T12:22:00.000Z;1;"" [0];"" [0];---------;0 < 2022-05-03 17:06:38.261 Script: D--------- 0 0 .. < 2022-05-03 17:06:38.261 Script: ---------- 0 1 May 3 14:22 FILE1 < 2022-05-03 17:06:38.261 Script: ---------- 0 1 May 3 14:22 FILE3
> 2022-05-03 17:04:14.442 Script: ls . 2022-05-03 17:04:14.442 Retrieving directory listing... > 2022-05-03 17:04:14.442 TYPE A < 2022-05-03 17:04:14.445 200 Representation type is Ascii NonPrint > 2022-05-03 17:04:14.445 PASV < 2022-05-03 17:04:14.448 227 Entering Passive Mode (*,*,*,*,15,172) > 2022-05-03 17:04:14.448 LIST . 2022-05-03 17:04:14.448 Connecting to *.*.*.*:4012 ... < 2022-05-03 17:04:14.462 125 List started OK . 2022-05-03 17:04:14.463 Session ID reused . 2022-05-03 17:04:14.463 Using TLSv1.2, cipher TLSv1.2: ECDHE-RSA-AES256-GCM-SHA384, 2048 bit RSA, ECDHE-RSA-AES256-GCM-SHA384 TLSv1.2 Kx=ECDH Au=RSA Enc=AESGCM(256) Mac=AEAD . 2022-05-03 17:04:14.463 TLS connection established . 2022-05-03 17:04:14.466 Data connection closed . 2022-05-03 17:04:14.466 Name VV.MM Created Changed Size Init Mod Id . 2022-05-03 17:04:14.466 FILE1 01.00 2022/05/03 2022/05/03 14:22 1 1 0 CIETPFM . 2022-05-03 17:04:14.466 FILE2 . 2022-05-03 17:04:14.466 FILE3 01.00 2022/05/03 2022/05/03 14:22 1 1 0 CIETPFM < 2022-05-03 17:04:14.468 250 List completed successfully. . 2022-05-03 17:04:14.468 Directory listing successful . 2022-05-03 17:04:14.468 ..;D;0;1899-12-30T01:00:00.000Z;0;"" [0];"" [0];---------;0 . 2022-05-03 17:04:14.468 FILE1;-;1;2022-05-03T12:22:00.000Z;1;"" [0];"" [0];---------;0 . 2022-05-03 17:04:14.468 FILE2;-;1;2022-05-03T12:22:00.000Z;1;"FILE2" [0];"" [0];---------;0 . 2022-05-03 17:04:14.468 FILE3;-;1;2022-05-03T12:22:00.000Z;1;"" [0];"" [0];---------;0 < 2022-05-03 17:04:14.468 Script: D--------- 0 0 .. < 2022-05-03 17:04:14.469 Script: ---------- 0 1 May 3 14:22 FILE1 < 2022-05-03 17:04:14.469 Script: ---------- 0 FILE2 1 May 3 14:22 FILE2 < 2022-05-03 17:04:14.469 Script: ---------- 0 1 May 3 14:22 FILE3
