Option to swap local and remote sides
Kacy_Stocks
Washington, Utah
As a developer, I find myself bothered by the tab headers being on the left side, while the remote is on the left.
I would prefer to have them be able to be over each other.
That, an option to have the tab headers right justified, or both.
Re: Option to swap local and remote sides
The tabs are above both panels, not the left one. Because both panels belong to the tab. Both panels change, when you switch a tab (At least with the default settings).
