PowerShell session log rotation
cipo80
Vicenza, Itay
Hi all,
just implemented the PS script provided by "the great" Martin/WinSCP portal to move files on local folder after uploaded and working very good.
I've insert only a $Session.SessionLogPath to write a log session and it's working, but the file increase daily.
I want to set a maximum log file size and a rotation to keep the last 7 files, is it possible?
Thank you
param (
    $localPath = "",
    $remotePath = "",
    $backupPath = "",
    $winSCPPath = "C:\Program Files (x86)\WinSCP\WinSCPnet.dll",
    $logPath = ""
try
    # Load WinSCP .NET assembly
    Add-Type -Path $winSCPPath
    # Setup session options
        HostName = ""
        UserName = ""
        Password = ""
        SshHostKeyFingerprint = ""
    # Log
    $Session.SessionLogPath = $logPath
    try
        # Connect
        # Upload files, collect results
        $transferResult = $session.PutFiles($localPath, $remotePath)
        # Iterate over every transfer
        foreach ($transfer in $transferResult.Transfers)
            # Success or error?
            if ($transfer.Error -eq $Null)
                Write-Host "Upload of $($transfer.FileName) succeeded, moving to backup"
                # Upload succeeded, move source file to backup
                Move-Item $transfer.FileName $backupPath
            else
                Write-Host "Upload of $($transfer.FileName) failed: $($transfer.Error.Message)"
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
