Slow download using .GetFileToDirectory if directory has about 130.000 files
LukasKarner
I am currently having trouble downloading a small file from an FTP server using the WinSCP .NET assembly (C#).
I tried using the .GetFileToDirectory and .GetFiles method.
The WinSCP version I am using is 5.19.6 on Windows 10.
The problem is: It takes a long time to download a small file if the folder it is in has a lot of files in it.
In our case, it takes between 19 and 50 seconds to download a 21 KB file from a folder that has about 130.000 files in it.
From what I have read in other posts and could see in the log files, the method sends a "LIST" command upfront, which appears to be the cause of this delay.
This behavior is present both on a client FTP server and our own FTP server.
I have attached the log files we got from our FTP server using the .GetFileToDirectory method.
I have also tried adding the RawSetting "FtpUseMlsd". "0" resulted in "Could not retrieve file information" and "1" had no change.
Can you tell me if I can disable this list command? Or is there a better solution, how to download a specific file from a folder with thousands of files in it?
Regards Lukas
  • test06-02-2022_remote.7z (251.79 KB, Private file)
tuliomarostegon
brazil
Same Scenario - Slow download using .GetFileToDirectory
Hi martin, I have the same scenario here, can you help me about it? i'm trying to download about 2.6k files.
I'm using the method GetFilesToDirectory to, here is my code attached
I tried to recover the log, which even Lukas did, but I was not successful, please let me know case it's necessary considering that it's probably the same case.
Regards!
  • DownloadFTPFilesUsingWINScp.txt (1.11 KB, Private file)
Description: Code
Re: Same Scenario - Slow download using .GetFileToDirectory
@tuliomarostegon: Please attach a full session log file showing the problem (using the latest version of WinSCP).
Btw, this is pointless:
option.TlsHostCertificateFingerprint = session.ScanFingerprint(option, "SHA-256");
It's an ineffective way to do the same as
option.GiveUpSecurityAndAcceptAnyTlsHostCertificate = true;
As the property name suggests, it's not best thing to do.
Another thing is that you are not calling TransferOperationResult.Check.
See https://winscp.net/eng/docs/library_session#results
