Command to Quick Deleting
Re: Command to Quick Deleting
Well, you didn't really explain why you cannot delete the file.
I'd assume that you miss "yes" option in the drop down. If that's the case, it's misunderstanding. The dropdown does not contain options to select from. The drop down contains answer history. Note that the custom command definition does not (and cannot) contain any list of the answers. WinSCP cannot magically come up with the list of possible answers.
You have to type the "yes" into the box.
If I misunderstood your problem, please explain.
TAIFUN
TAIFUN avatar
After adding the command, there is no option "Yes" in the window, there is only "no".
Lol. I didn't know that it was necessary to print the word "Yes". I was waiting for the "Yes" option in the drop-down list. )
