The file in destination is renamed, when doing the upload using WinSCP .NET assembly
aria4ca
Dear support,
The file in destination is renamed, when doing the upload using WinSCP .NET assembly. For instance, if the source file name is MyTest.csv, the file name in destination is not closely reflecting this name.
We used the following approaches but they didn't help:
1- update winScp.ini file to include:
[Configuration\Interface\CopyParam]
ResumeSupport=2
2- Add the same logic in the code:(make the TransferResumeSupport to be 'Off')
TransferResumeSupport transResumeSupport = transferOptions.ResumeSupport;
transResumeSupport.State = TransferResumeSupportState::Off;
Would you please advise,
