File Colors Setting Bug
After updating WinSCP to version 5.21, the File Colors setting on the remote pane side no longer works. The local pane side is working fine.
Before updating to version 5.21, in version 5.19.6, the remote pane side was also displayed correctly.
The File Colors settings are, for example:
The OS is Windows 10 Pro.
Dir-010/; Dir-011/; Dir-015/; Dir-021/; Dir-022/
