Can't use %APPDATA% in "Custom INI file:", but I can in "Random seed file:"
Sopor
Sopor avatar
Sweden
I want to have the path to my WinSCP.ini like this %APPDATA%\WinSCP\WinSCP.ini, but if I try that I get an error message (see attached file).
I can use %APPDATA%\WinSCP\winscp.rnd for the seed file without any error message.
I don't have any winscp.rnd file in %APPDATA%\WinSCP\, though.
Maybe that path is invalid for the seed file too? The only difference is that it won't show an error message?
After changing the path to C:\Users\<username>\AppData\Roaming\WinSCP\winscp.rnd I now have a winscp.rnd file too.
Re: Can't use %APPDATA% in "Custom INI file:", but i can in "Random seed file:"
You can use /ini=%APPDATA%\WinSCP\WinSCP.ini command-line switch, if you want to use environment variables. You can create a desktop shortcut for that.
Sopor
Sopor avatar
Sweden
I don't know how it should work, but if I get an error message when I use %APPDATA% in the INI path. Shouldn't it show the same error message in the seed file path when I use %APPDATA%?
Will WinSCP work without a seed file? I don't really know what it do, but I didn't have one in my folder.
BTW, why isn't variables supported like most other Windows program?
You mean you get an error even when you use /ini=%APPDATA%\WinSCP\WinSCP.ini?
Currently all errors when writing the random seed file are silently ignored. WinSCP works without random seed file, but it degrades security.
What "most other Windows program" have similar configuration that allows using environment variables?
Sopor
Sopor avatar
Sweden
No, I haven't tried /ini= yet.
If more than one account use WinSCP, how will that work if it won't support variable names?
If I open the dropdown menu for external applications I will find this line:
%ProgramFiles%\PuTTY\putty.exe -t -m "%TEMP%\putty.txt" !`cmd.exe /c echo cd '!/' ; /bin/bash -login > "%TEMP%\putty.txt"`
So, it looks like it will work, but not everywhere 😊
What will work? The /ini=%APPDATA%\WinSCP\WinSCP.ini? The %APPDATA% in shortcut target is resolved by Windows shell before executing WinSCP.
And yes, WinSCP supports environment variables in PuTTY command-line. That's imo quite irrelevant here.
Sopor
Sopor avatar
Sweden
So, you mean that every user that run WinSCP have to add /ini=%APPDATA%\WinSCP\WinSCP.ini as a command line switch to the shortcut?
That sounds a bit too complex for the regular user. That should be supported by default.
That is why i found it a bit weird that it won't supports it in the Configuration storage paths.
johnwick6
GUEST POST
Get help and report bugs here. I'll try to answer your questions as soon as possible. Maybe other users answer you faster. Before posting, please learn How to ask for support or report bug.
MALIK66
Reply with quote E-mail
Sopor
Sopor avatar
I have tried to use Automatic INI file but it will only mess it up for me.
Strange that it use %APPDATA% in Automatic INI file, but I can't manually use it in Custom INI file. 😥
