Session.GetFiles not able to delete remote files
teyers@paragonhealthcare.com
I am using the following script to push and pull files from several sites without any issues. As part of the script it is set to remove the files once they have been pushed or pulled successfully. I have one site that is not allowing the script to remove the remote files after a successful GetFiles. It appears to be something on the providers side, but I am not sure what to tell them or to get a workaround on my side. Any clues as to what's going on?
The only error message I see is the following:
Transfers Failures
{}        {WinSCP.SessionRemoteException: Error deleting file '/out/.working'....
Script:
try
    $OUTLocalPath = "\\SERVERNAME\OUTBOUND\*"
    $OUTRemotePath = "/in/"
    $INLocalPath = "\\SERVERNAME\INBOUND\"
    $INRemotePath = "./out/*"
    $ArhivePath = "\\\SERVERNAME\Archive\"
    # Make an Arvhive copy
    Copy-Item -Path $OUTLocalPath -Destination $ArhivePath -Recurse
    try
        # Connect
        # Upload files
        $transferOptions.TransferMode = [WinSCP.TransferMode]::Binary
        $transferResult =
            $session.PutFiles($OUTLocalPath,$OUTRemotePath , $True, $transferOptions)
            $session.GetFiles($INRemotePath,$INLocalPath,$True, $transferOptions)
        # Throw on any error
        $transferResult.Check()
        # Print results
        foreach ($transfer in $transferResult.Transfers)
            Write-Host "Upload of $($transfer.FileName) succeeded"
    finally
        # Disconnect, clean up
        $session.Dispose()
    #exit 0
catch
    #exit 1
Re: Session.GetFiles not able to delete remote files
Btw, you are not checking results of session.GetFiles – The indentation of that code is confusing.
