Open file on server in external editor via WinSCP CLI
roofwoof
Hello!
I have two files on server (SSH-connection). I'm usually open WinSCP GUI-client and open them in Brackets. I configured the Editor preference table in such way that WinSCP opens HTML, CSS and JS files via Brackets. Now I want to automatize this actions using batch or PowerShell script. I want to open WinSCP GUI and open two files in Brackets via batch script. So I wrote the batch-code below:
start winscp.exe <session_name>
winscp.exe <session_name> /edit <path>/my_styles.css
winscp.exe <session_name> /edit <path>/my_script.js
But WinSCP opens these files via internal editor. How can I configure the editor in CLI?
roofwoof
Re: Open file on server in external editor via WinSCP CLI
When you use WinSCP GUI and open the file WinSCP saves it to temporary directory, then runs external editor to open this file.
Why can't it be implemented in CLI?
When you open the editor in GUI, you control, when the connection is closed by the WinSCP GUI.
But if you open an external editor from commandline, there won't be any WinSCP GUI. How would you tell WinSCP to close the connection?
roofwoof
Okay, I understood the problem. Maybe it is possible to run session in command line or just run the GUI and open files in its session? I understand that it is a bit complicated to implement.
Thanks for your suggestions. We will see, if more people ask for this.
