WinSCP latest version 5.21.1 is not working for one vendor SFTP get files
SrideviReddy
We are experiencing issues with new WinSCP 5.21.1 from using get command to retrieve files from a vendor site.
Will someone shed some light on this.
We see these in the logs which is unusual Listing file "/ACTUALDIRECTORY/..".
Is there something we are missing after upgrading to new version of WinSCP?
It worked for 5.19 but not for 5.20
Please let me know if there is any help that can be offered.
Re: WinSCP latest version 5.21.1 is not working for one vendor SFTP get files
Please attach a full session log file showing the problem (using the latest version of WinSCP). A log file of equivalent working session from 5.19 might help too.
