Synchronize Files and Directories
stangredi@...
I have a script to synchronize a folder on an SFTP site to a local network drive. New files and directories are not getting copied
synchronize local "Network Drive" "Folder on SFTP site" -criteria=time,size
Re: Synchronize Files and Directories
