Lagging when moving between two displays with different scale on Win11
kaen
When i try to mov program window between two displays, the application is trying to change scale and hangs.
Jens
I can confirm this issue. An easy fix that worked for me:
  • Go to WinSCP shortcut or exe file.
  • Open Properties.
  • Choose "Compatibility" settings.
  • Click on "Change high DPI settings"
  • Select "High DPI scaling override".
  • Choose "System (Enhanced)"
  • Restart WinSCP.
Works perfectly fine for me.
@Jens: What do you confirm? The lag (temporarily) or hang (forever)? Thanks.
Changing compatibility settings makes WinSCP burry at high DPI display – although it may solve the lag. For me, the lag is very short (one second at most). If WinSCP hangs or lags significantly longer for you, I'd like to know.
