Disable inplace renaming
Sopor
Sopor avatar
Sweden
When browsing around in WinSCP it happens too often that instead of open the folder it will trigger the inplace renaming.
I haven't found a way to disable it, so could you add an option to disable inplace renaming?
If I want to rename a folder/file I can always use F2 or the context menu, so there is no need for the inplace renaming.
