Ignore TLS/SSL in WinSCP using S3 protocol
I have a localhost MinIO bucket running on HTTP. I want to connect to it via the WinSCP client. It's failed with error [quote]"SSL handshake failed: SSL error:wrong version number"[/quote]. I did try to change the version my client is using and it failed. I believe its failing since the MinIO bucket isn't using HTTPS.
If that is the issue – Is there a way to ignore TLS/SSL in WinSCP using S3 protocol?
I've attached logs of an attempt to login to the bucket.
