Get command not working for automated download
Celeste_Smith
I am currently using version 5.19.6 of WinSCP on a 2021R2 Windows server. I have no issue writing upload scripts, but can't get the download automated with a get script. I am using the script generated in the Transfer menu and can connect to the SFTP. However, I then get "get is not a command" or the batch file opens and closes immediately. When using pause it tells me it can't find a directory, or several other errors as I try and move quotes, or make adjustments. When I manually transfer/download I have not issues. Any advice would be appreciated.
Description: Image of session generated script. Potential sensitive info blacked out.
Re: Get command not working for automated download
Please post the script as a text, not as an image. Also post the log file. And exact error message you get for the exact script you post.
