Session.CompareDirectories – No diffs found
Michael3
I'm using Session.CompareDirectories to get list of all diffs between local path and remote path.
The function return diffs only if the file not exists in remote. if the file changes (data or size) I can't see it in the diffs list.
if (session.FileExists(remotePath2))
    compareDiffs =
        session.CompareDirectories(
            SynchronizationMode.Remote, projectSyncPath + "/", remotePath2,
            true, false, SynchronizationCriteria.Either);
    count += compareDiffs.Count;
    if (compareDiffs.Count > 0)
        SaveDiffPath(componentDirectoryName, compareDiffs);
My path are correct.
Appreciate any help.
Re: Session.CompareDirectories – No diffs found
Please attach a full session log file showing the problem (using the latest version of WinSCP). Give us a name of a file that you believe should have been identified as different but was not.
Btw, do not append a forward slash to a local path.
