PAM Integration with WinSCP
VinceVince
WinSCP 5.21.1
Has anybody here ever integrated WinSCP with Thycotic Secret Server?
To make a long story short, WinSCP expects a filepath for the SSH key but Secret Server expects the key itself. Thus we are force to use the 'Proxy' feature of Secret Server which logins with temp creds and then passes the key internally. When doing so, WinSCP always return 'Cannot initialize SFTP protocol. Is the host running an SFTP server?'. This does NOT happen if we do no use the proxy feature.
Vince
nolo
Dear VinceVince,
I am having the same issue:
I need to connect to some Linux machines using PAM + proxy.
Since I have configured all secrets via PAM + proxy I can no longer open connections with WinSCP. Only SSH connection works, but not WinSCP connections.
I kindly ask if you can tell me what solution you have adopted
thank you
nolo
@nolo: It's unlikely you get an answer form an anonymous user, who posted months ago.
Please give us more details about your setup. Logs files might help too. Did you test other SFTP clients?
nolo
Dear @Martin,
sorry for my late reply and thanks for your answer.
Regarding the initial issue, I found two video that helped me to configure WinSCP on Secret Server:
https://vimeo.com/689362569/d941324b2c
https://vimeo.com/689362641/f7d77bdea7
I had to change some options because the video it is from an old version:
"Launcher Type" --> Proxied SSH Process
"Use SFTP Tunneling with SSH Proxy" --> tick this option
After this configurations, I can access via WinSCP (through the Secret Server proxy) all VM's Linux. But I have to use the Secret Server web interface.
At the moment I not yet been able to access directly from WinSCP without going through Secret Server Web interface. (I am not sure if that is currently possible with Secret Server).
Anyway, for me it is already a good compromise.
thank you
regards,
nolo
