Host is not communicating for more than 15 seconds
nathanuel.williams@gtdsol
Good afternoon,
One of my colleagues has experienced the message host is not communicating for more than 15 seconds. Are you able to assist?
Regards
Nathanuel
Re: Host is not communicating for more than 15 seconds
Are you able to connect to the same server with the same credentials from the same local network, where you colleague is not? Can you post log files from yours and your colleague's session?
