Bug: Broken ssh-key-auth in Keep remote directory up to date
Darbk
After update WinSCP 5.21.1 to 5.21.2 noticed that SSH key-based authentication did not applied when use "Start in New Window" in "Keep Remote Directory up to date" function. WinSCP asked to enter username and password despite that username and SSH private key are saved and successfully used to auth in New Session or PuTTY. Rolling back to WinSCP 5.21.1 solved the problem.
Re: Bug: Broken ssh-key-auth in Keep remote directory up to date
I have added this issue to the tracker:
Issue 2104 – Opening session in new window fails
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include a link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
