Azure Function App - Nested Bin Directories
I have installed WinSCP into an Azure Function App via NuGet. On build, I can see that both the exe and dll are in the
However, when running the app locally, I get the "winscp.exe executable was not found at location of the assembly WinSCPnet" error. What is happening is that its looking for the exe in a nested
What is going on here? How do we get the exe to be copied over to the nested
NestedBinMan
\bin\Debug\netcoreapp3.1
directory.
bin
dir, namely \bin\Debug\netcoreapp3.1\bin
The exe does not exist here, only WinSCPnet.dll If I copy the exe into this nested bin
all is well.
bin
? Or is there some issue causing the nested bin
to appear in the first place?
NestedBinMan
