S3 Session.Open failing on Session.HomePath
Cstro2022
I am trying to get generated code to work in a VB Script, but it fails within the WinSCP DLL at Session.HomePath with this error
"Session.HomePath' threw an exception of type 'System.InvalidOperationException' String {System.InvalidOperationException}"
Any ideas ?
Below is the script with my access and secret removed, it is trying to access a public S3 site, so anyone can put in their Access Key and Secret and you should be able to access the site.
' Set up session options
With sessionOptions
    .Protocol = Protocol.S3
    .HostName = "s3.amazonaws.com"
    .UserName = "xxxxxxxxx"     'Access Key
    .Password = "xxxxxxxxxxxx"       'Secret
End With
sessionOptions.AddRawSettings("S3DefaultRegion", "us-east-1")
sessionOptions.AddRawSettings("S3UrlStyle", "1")
Using session As New Session
    ' Connect
    session.Open(sessionOptions)   'fails here
    ' Transfer files
    session.GetFiles("/gov-fpac-rma-pubfs-production/pub/References/actuarial_data_master/2023/2023_ADM_Daily_220815.zip", "C:\temp\*").Check()
End Using
Re: S3 Session.Open failing on Session.HomePath
Your code is not accessing Session.HomePath at all. It cannot be throwing that exception. Double check what code did actually threw that error.
