How to increase the number of columns to transfer a file from Windows to MCP
Andres Gomez
Hello, I am trying to transfer a file .txt by SFTP. It has more than 150 columns, the problem is that in column 80 is giving a line jump
    Protocol = Protocol.Sftp,
    HostName = "10.0.0.7",
    PortNumber = 2222,
    UserName = "user",
    Password = "password",
    SshHostKeyFingerprint = "ssh-rsa 2048 xxxxx"
    // Connect
    session.Open(sessionOptions);
    // Upload files
    TransferOptions transferOptions = new TransferOptions
    { TransferMode = TransferMode.Automatic, };
    session.PutFiles(@"C:\Temp\LOTE1808.035", "/public/test2/", false, transferOptions).Check();
Re: How to increase the number of columns to transfer a file from Windows to MCP
Your code should be using binary transfer mode. So WinSCP should not be modifying the file anyhow. If you file is modified anyway, it is unlikely a WinSCP issue. Either the file was modified before or after the transfer by other systems. If you want us to check anyway, post a session log file.
