Can't edit a file via FTP with VSCode
Palteza
France
Hi there,
I'm using WinSCP 5.21.3 on Windows 10. I'm connecting to a FTP.
I've added VSCode as external editor in the settings, when I try to open a php or html file, VSCode is opening, he tries to load something, but the file is not opening then, nothing happening.
When I try to open a 2nd the same file, I have a message saying "The file xxx is already opened in the editor or is currently opening".
I've tried to install user and system verions of VSCode, I meet the same issue.
Thanks in advance.
Palteza
France
Hey,
Thanks for your reply.
I've joined 2 screenshots.
The path in WinSCP is good since VSCode launches when I want to open a file.
I took a screenshot of VSCode but there is nothing special (it tries to load something during 4-5sec, I can see it on the pointer).
Palteza
France
Yeah, I've just tried to click Edit manually just in case.
That's weird, must come from my Windows.
Thanks anyway.
And can you even open a local file from VSCode commandline?
The "The file xxx is already opened in the editor or is currently opening" message comes from VSCode, right? (not from WinSCP)
Palteza
France
Your question solved the problem.
Actually, since it was a new VSCode installation, I didn't even try to open a 1st local file before testing from WinSCP.
So I've just tried, locally, and the classic 1st time window was displayed, something around
Are you sure you want to open a file from this source blablabla blablabla
It was this step which was blocking via WinSCP (the window not showing up)
Now it's working fine again from WinSCP.
Thanks for your help !
