No warning for overwriting files with same name
On my WWW site I have a folder (
In that folder is a folder (
If I go into the
But in doing so, it overwrites everything in the pix1 directory. Although I really want to do this, there is no warning like "do you really want to overwrite these files," just in case I really wanted to move the
pix1
, etc.
pixbig
) which also contains bigger versions of the same pictures, with the same names as those above.
If I go into the
pixbig
folder, select all and drag everything up to the top of the screen where there is the ..
meaning "the directory above" and drop the bigger pictures, it will move everything to the pix1
directory.
pix1
stuff away first. Is it possible to do implement a warning like this?
