WinSCP | Synchronize issue
Anonymous 6
I have setup a scheduler which will synchronize a folder from source to multiple target servers using FTPS.
Application used to synchronize the files properly on scheduled time except twice a day. The scheduler will take more than 3 hours to copy file ~1 MB which is to happen in just a minute.
Syntax used:
synchronize remote -mirror -delete -criteria=either -transfer=binary -filemask="*/ | one.txt" "<xxx path>" "/"
Re: WinSCP | Synchronize issue
Anonymous 6
Hi Martin,
The issue is resolved, it was an issue from network end at the particular time.
I think we can close this ticket.
