FTP transfer as fast as FileZilla?
Blawdi
France
Hello, with my WinSCP I have a configuration problem, I would like it to be as fast as FileZilla for batch file transfer.
I often have hundreds of thousands of files of some MO to download, but it is just impossible with WinSCP.
In default, it takes about 30 min for 100 mb, if I activate the background, it loads in loop without downloading the files (I didn't let it run for long, but I would like it to be instantaneous, you ask for the copy, it copies directly, without having to calculate anything.
Is this possible?
Re: FTP transfer as fast as FileZilla?
What does it mean "it loads in loop"? Can you post a session log file (and maybe some screenshot[s]) documenting the problem?
Blawdi
France
Sorry for the delay in answering but I was on FileZilla !
However, nothing to do your software is better on all the other points that the file transfer!
For example :
With FileZilla I transfer a Prestashop site it takes me +-5 Min
With WinSCP I transfer the same site, on the same server, it takes +- 30 min...
I don't touch anything in the settings :( I don't understand why it's so slow with winscp! one file transfers fast... but as soon as there are many small files it's slow.
I guess it's because FileZilla connects several times while winscp does not?
Translated with www.DeepL.com/Translator (free version)
Blawdi
France
I'm not sure I understand, I have trouble with English, I'm a French speaker, but in the descriptions I read
That with several connections it does not slow down the transfer. I have checked "Use multiple connections for a single transfer".
But when I copy a folder to my PC, it says in progress "Display content..." it's long no way to make it instant without calculation or other?
Willi
Speed comparison between Filezilla and winscp
Hi, I am new here, but I used WinSCP for many years. Since some months, I noted that the download of long files is very slow during the first half of the transfer. Typically, the transfer starts with somewhat more than 1 MBytes/s, but slows down to about 0.3 MBytes/s hereafter. When about 50% of the file is transferred, the speed may accelerate instantly to much more than 10 MBytes/s, so, the second half of the transfer is much much faster.
Today, I tested FileZilla and was really astonished to note a continuous and stable transfer speed of about 70 MBytes/s. Two .mp4 files, 33 GBytes in total, were downloaded in less than 8 minutes!. I tested a much shorter .mp4 with WinSCP hereafter but stopped when I noted again the slow transfer rate mentioned above.
Is there any reason for this boring behaviour of WinSCP?
I use SFTP.
Re: Speed comparison between Filezilla and winscp
@Willi: Please start a new thread and post session log files both from WinSCP and FileZilla (both latest versions, both running on the same machine).
