IPV6 Compatibility - Mandate 2025
jbracco1180
WinSCP WinSCP Martin Prikryl 5.17.10 Open source
WinSCP WinSCP Martin Prikryl 5.19.5 Open source
WinSCP WinSCP Martin Prikryl 5.19.6 Open source
WinSCP WinSCP Martin Prikryl 5.21.1 Open source
WinSCP WinSCP Martin Prikryl 5.21.2 Open source
WinSCP WinSCP Martin Prikryl 5.21.3 Open source
WinSCP WinSCP Martin Prikryl 5.9.6 Open source
UCOR is under OMB mandate M-21-07 which requires us to transition to IPv6 only by 2025.
  1. Does software/version above support running on a dual stacked O/S with IPv4 with IPv6?
  2. Does software/version above support running on an IPv6 only O/S?
  3. If so, do you have any special configuration instructions?
  4. If not, do you have a timeframe for upgrading the application to support IPv6?
https://web.archive.org/web/20250116092323/https://www.whitehouse.gov/wp-content/uploads/2020/11/M-21-07.pdf
Re: IPV6 Compatibility - Mandate 2025
This is hard question to answer definitively.
We do not explicitly test WinSCP on IPv6-only network.
Also IPv6 support will likely somewhat vary with protocol used.
Though we didn't receive any report regarding problem on IPv6-only network, so I believe WinSCP should support them (at least with widely used protocols such as SFTP and FTP).
