Command line return nothing but host
bananapun
Hi. I am using the command line options. something like this
WinSCP.com /ini=nul /command open -hostkey=acceptnew -password=password sftp://username@ipaddress get /home/username/Windows_resource/md5.txt exit
Executing above command returns searching for host, refer below
Opening session using command-line parameter in scripting is deprecated. Use 'open' command instead.
Searching for host...
Connecting to host...
Authenticating...
Using username "username".
Authenticated.
Starting the session...
Session started.
Active session: [1] username@ipaddress
Host:
Host:
Host:
Host:
Host:
Host:
Host:
Host:
Host:
Host:
Host:
Host:
Host:
Host:
Host:
Host:
Host:
Host:
Host:
Host:
Host:
Is my syntax wrong?
bananapun
re: Command line return nothing but host
Not sure what is the issue here. So I think I will stick with the the scripting method and invoke the script from the command line instead. Should be ok.
bananapun
re
Ah ok I get the problem now
WinSCP.com /ini=nul /command 'open -hostkey=acceptnew -password=password sftp://username@ipaddress' 'get /home/username/Windows_resource/md5.txt' 'exit'
Need to add quotation.
