Nothing to Syncronize
yorwos
sqltransfer.txt
open ftp://user:pass@server:ip/
synchronize remote -resumesupport=on -criteria=either "E:\srg\auto\" "./pylon/"
sqltransfer.bat
winscp.com /script=sqltransfer.txt /loglevel=1 /log=log.log
2022-11-03 08:12:05.914 Remote file './pylon/XenosAE_FULL_11022022_213441.BAK' [2022-11-03T06:09:43.000Z] [3414276] is modified comparing to local file 'E:\srg\auto\XenosAE_FULL_11022022_213441.BAK' [2022-11-02T19:35:29.934Z] [1343254016]
< 2022-11-03 08:12:05.914 Script: Nothing to synchronize.
. 2022-11-03 08:12:05.914 Session upkeep
> 2022-11-03 08:12:05.914 Script: exit
. 2022-11-03 08:12:05.914 Script: Exit code: 0
. 2022-11-03 08:12:05.914 Script: Max roundtrip: 0
. 2022-11-03 08:12:05.914 Got reply 1004 to the command 2
. 2022-11-03 08:12:05.914 Disconnected from server
yorwos
Re: Nothing to Syncronize
The thing is that there IS A FILE that is different. But it won't sync it. What's wrong? I created another text file, and it just synced that one. The file in question is 1.3GB maybe that's the reason? I have plenty of free space on my NAS.
Please attach a full session log file showing the problem (using the latest version of WinSCP). Give us a name of the file to look for in the log.
